Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - ZETEC Timing Belt Replacement
Old 06-09-2010, 03:08 PM   #73
the_doc735
Fan#: 74469
What I Drive: focus lx blue
FF Reputation: 1 the_doc735 Good Standing Member
Originally Posted by Jon_SVT View Post
Good call... I haven't started yet. I gotta get a cherry picker to pull the engien up high enough to get a straight tap/drill bit into it. Can't do precision work, working at an angle really....
I think I'll do just that, tap it to an imperial bolt then try that route. What size would be the next one up from an 8mm metric bolt?
* 1mm = just over 1/32 inch
* 2mm = just over 1/16 inch
* 3mm = almost 1/8 inch
* 4mm = 5/32 inch (= a bit over 1/8 inch)
* 5mm = just over 3/16 inch
* 6mm = almost 1/4 inch
* 7mm = almost 9/32 inch (= a bit over 1/4 inch)
* 8mm = 5/16 inch
* 9mm = almost 3/8 inch
* 10mm = just over 3/8 inch
* 11mm = almost 7/16 inch
* 12mm = almost 15/32 inch (= almost 1/2 inch)
* 13mm = just over 1/2 inch
* 14mm = almost 9/16 inch
* 15mm = almost 19/32 inch
* 16mm = 5/8 inch
* 17mm = almost 11/16 inch
* 18mm = just over 11/16 inch
* 19mm = 3/4 inch
* 20mm = 25/32 inch
* 21mm = just over 13/16 inch
* 22mm = almost 7/8 inch
* 23mm = 29/32 inch
* 24mm = just over 15/16 inch
* 25mm = almost 1 inch
Also, can't you use a 90 [right angle] drill adapter; that should go in the available spacer easier, maybe not require any engine lift?
the_doc735 is offline
