Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - ZETEC Timing Belt Replacement
Old 06-08-2010, 09:29 AM   #66
Jon_SVT
Jon_SVT's Avatar
Fan#: 34787
What I Drive: 2002 Silver SVT Focus
Points 677, Level 13
Points: 677, Level: 13 Points: 677, Level: 13 Points: 677, Level: 13
Level Up 54% Completed
FF Reputation: 2 Jon_SVT Good Standing Member
Exclamation
Question to anyone out there:
we got pretty much everything in, new timing belt, new water pump, pulleys, tensioners etc but we made a boo-boo.... stripped the hole where the water pump screws go into the block. The hole is F'd but the screw is fine...... any suggestions on what our options are?
I was thinking of unbuttoning all 3 motor mounts, undoing exhaust manifold somewhere then hoisting the engine up high enough to get a straight drill bit into it to insert some helicoils. Suggestions please!! you can only imagine howmuch I'm freakin out over here when the water pump won't bolt in tight
Loyal Focus Owner!!!
First: 2003 Ford Focus ZX5
Second: 2002 Ford Focus SVT (#2808 of 4788)
Jon_SVT is offline
