Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SVT Clutch replacement completed (pics)
Old 06-06-2010, 08:53 PM   #8
nacnudv8's Avatar
Fan#: 52725
What I Drive: former owner:Pitch Black '03 SVT 3D
FF Reputation: 7 nacnudv8 Good Standing Member
Buy-Sell-Trade Rating: (5)
Originally Posted by BC_ZX3 View Post
That'd be "For The Win".
Thanks BC_ZX3 - learn something every day!
So I'm curious as to whether a simple replacement of the faulty clutch disc (and a thorough cleaning) solved your problem
- No I replaced the clutch and therefore had to change the flywheel as mine was the original pre-TSB version. The new style OEM LUK clutch for the SVT is a bit larger in dia. so it needs a new flywheel too.
It was not cheap! C F M in Florida sold me the kit which included the through-out bearing, pressure plate and the alignment tool.
arlenn - regarding your question - I'll go now and post some pics of the flywheel and pressure plate - perhaps you both can shed some light on what happened. I think heat with a worn friction material did it.
It was the non-flywheel side of the clutch that was distroyed.
And BTW at the time I was passing an old slow 60's Camero at a normal speed and when I was level with him, he floored his throttle and tore off - I pursued and we got - - - then "pop" as I tried to sift down a gear and then was unable to change gear..... :(
An eye for an eye makes the whole world blind.
Mahatma Gandhi
nacnudv8 is offline
