Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Harness and Harness Bar
Old 05-31-2010, 01:00 PM   #2
mlbbaseball
Shot me 3 deer!!!
mlbbaseball's Avatar
Fan#: 53541
What I Drive: 2 SVTs, 1 V8 SVT & two 7.3L diesels
Points 29,963, Level 99
Points: 29,963, Level: 99 Points: 29,963, Level: 99 Points: 29,963, Level: 99
Level Up 98% Completed
FF Reputation: 42 mlbbaseball Great Standing Member
Buy-Sell-Trade Rating: (69)
well, i hope you got scroth belts. cause any 4 pt. isn't going to prevent submarining unless scroth belts are used. if you are not using quality belts, like 5 pt. 3 inch straps, ur 3 pt stock belt will be better!
as for mounting,
check out here, it shows how the manufacturer wants the belts to be routed. sroll to pg. 44.
http://www.rally-america.com/info/2010_Rally_America_Rule_Book.pdf
unfortunately, the only way ur belts will be safer is if you mount them properly, AND use a 5 pt or greater belt to prevent submarining.
also, what bar are you using? and what straps are you using? i'm assuming a codesvt bar? and i'd be interested in the belts your using too.
terminator v8 in an SVT focus (soon to be boosted @ 20 PSI with a 2.9 L Kenne Belle on Corn!!!
(750 rwp and low 10 second focus, here I come!)
mlbbaseball is offline
