Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - cooling fans not working... already replaced resistor
Old 05-25-2010, 08:44 AM   #10
4ST AIR
Fan#: 64583
What I Drive: 2004 Ford Focus ZTS
FF Reputation: 3 4ST AIR Good Standing Member
Originally Posted by Jboy1788 View Post
checked fuses and relays those are fine. fans spin smoothly and fans themselves do work w/ 12v direct to them..
This may be dumb, but it did happen to me. The 2nd fan fuse wiring went bad, burned out on the power side. I checked it with a test light, had power, then I removed it to look at it, and it was fine. Apparrently, it was burnt and barely connected, but not where you could see. placed the fuse back in, and couldn't figure out why the fans didn't work. Happen to run a test light on it later, and no power! Pulled the fuse again, noticed that it looked fine, but came out much easier...dismantled the fuse box, noticed that the wire was burnt up to the fuse connector inside the fuse box on the hot side of the fuse connection (about 1-1/2"). Repalced the wire, good to go. Did you check the relays and fuses by visual, or by test light? There should be power to the fan fuses with the ignition on. If not using a test light, try that. But then again, it sounds like you already may have done that...
4ST AIR is offline
