Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - cooling fans not working... already replaced resistor
Old 05-24-2010, 11:08 PM   #9
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 31,378, Level 100
Points: 31,378, Level: 100 Points: 31,378, Level: 100 Points: 31,378, Level: 100
Forum Activity 100%
FF Reputation: 133 sailor Excellent Standing Member sailor Excellent Standing Member
Originally Posted by Jboy1788 View Post
so as title says my cooling fans are not working both of them... a/c blows warm air. replaced the resistor two weeks ago thought it might have went out again got a new one... didn't fix it... checked the pig tail and it has power no prob so no burnt wires... what else could be the prob / what should i test for now???
2001 5 spd zetec dohc w/ a/c
Posted via FF MobileIf the pigtail has power, and resistors are good, a connection to the fans and a good ground is all you need... So, test for ground at fan connector/trace back as needed.. good ground? then that "power` is just a voltage reading, no ampps to run fans, so a bad connection on that side somewhere.
sailor is offline
