Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - valve clearance problems
Old 05-24-2010, 06:06 PM   #6
Fan#: 21404
What I Drive: 04, CD Silver SVTF
Points 542, Level 10
Points: 542, Level: 10 Points: 542, Level: 10 Points: 542, Level: 10
Level Up 84% Completed
Level up: 84% Level up: 84% Level up: 84%
FF Reputation: 8 RecoilRob Good Standing Member
Have you installed the head yet? If not, and it always is a great idea to set valve clearances on the head before installing it, you can pull the cams and touch the head of the valve to reduce it a bit. I'm assuming your clearances are tight, yes? If loose, the seat needs sunk a bit to bring the valve up. Have you talked to the machine shop about this problem? My favorite guys here in town will work with me if I run into something like this. I tell them which valve needs to come up or down and how much and they make it so. Might be worth a call.....
RecoilRob is offline
