Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - ZETEC Timing Belt Replacement
Old 05-15-2010, 09:27 AM   #50
lhc_focus
Fan#: 42464
What I Drive: 2002 ZX5
Points 186,903, Level 100
Points: 186,903, Level: 100 Points: 186,903, Level: 100 Points: 186,903, Level: 100
FF Reputation: 11 lhc_focus Great Standing Member
Originally Posted by RickNC View Post
They are. The intake cam is slightly turned. I know that moving the crank to the pin isn't going to move the cams since there is no belt. However, from what I have read it seems that if the crank is against the pin and the cams are lined up all is good. No? I know I have lots of questions but the more I read on here the more confused I get. Everybody seems to say somethign different.
Sounds to me like you are very close with the cams. When I went to put the bar in the slots they were off about 1/8". I turned the cam just enough to slip the bar in place. Then put the pin in the hole. Now your good to go.
It will take several tries to get the belt on. If you don't keep the crank against the pin, there will be slop in the belt. Like I said, you'll get it after several tries. It does require patience, you got some on the shelve? LUK
lhc_focus is offline
