Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - ZETEC Timing Belt Replacement
Old 05-14-2010, 10:59 AM   #45
RickNC
RickNC's Avatar
Fan#: 38833
What I Drive: Focus
FF Reputation: 1 RickNC Good Standing Member
Originally Posted by sailor View Post
Posted via FF Mobile IF he was near TDC #1 when the belt came off! Otherwise you need to carefullt turn crank so pistons move toward center of stroke (plugs pulled) so they are away from valves. Then set cams to timing position. Then bring #1 piston to TDC . at that point you can proceed with normal timing instructions!
I was under the impression I could put the pin in and hit it with the crank and that would line up the cams. Then put the bar in and proceed. If not please let me know. I had to order the bar and pin online so the car is going to sit for a couple days.
RickNC is offline
