Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - ZETEC Timing Belt Replacement
Old 05-14-2010, 09:47 AM   #44
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 30,451, Level 100
Points: 30,451, Level: 100 Points: 30,451, Level: 100 Points: 30,451, Level: 100
Forum Activity 100%
FF Reputation: 127 sailor Excellent Standing Member sailor Excellent Standing Member
Posted via FF Mobile IF he was near TDC #1 when the belt came off! Otherwise you need to carefullt turn crank so pistons move toward center of stroke (plugs pulled) so they are away from valves. Then set cams to timing position. Then bring #1 piston to TDC . at that point you can proceed with normal timing instructions!
sailor is online now
