Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How-To: SVT Side Mirror Installation
Old 05-10-2010, 03:07 AM   #1
Tom
FF Founder
Tom's Avatar
Fan#: 2
What I Drive: 2005 Saleen ZX3 SES Turbo
Points 88,854, Level 100
Points: 88,854, Level: 100 Points: 88,854, Level: 100 Points: 88,854, Level: 100
FF Reputation: 60 Tom Excellent Standing Member
Buy-Sell-Trade Rating: (7)
Items Needed:
1) Two SVT Side Mirrors (Will require painting) Part# FO1320314 (Left) & FO1321314 (Right)
2) Socket/Ratchet
3) Torx Screwdriver
Step 1:
Remove the plastic cover. Start by gently pulling/lifting the backside and then pull the cover off.
Step 2:
Using a Torx Screwdriver, remove the mounting screw.
Step 3:
Unplug the Mirror.
Step 4:
Remove the rubber grommet. This thing falls off really easy so be careful.
Step 5:
Use a socket/rachet and remove the second mounting bolt. You will need to remove the foam insullation for easier access.
Step 6:
Remove the old side mirror.
Step 7:
Feed the wires from the new mirror through the hole.
Step 8:
Reinstall the rubber grommet.
Step 9:
Reinstall the side mirror.
Step 10:
Install the painted mirror caps. "I had a clear film installed to protect the pain against rock chips."
Keywords: svt mirror install, svt mirrors installation, svt side mirrors how to, svt mirror how to
Tom is offline
