Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - removal of crankshaft pulley bolt?
Old 05-08-2010, 06:18 PM   #110
Grumpy
Fan#: 43791
What I Drive: 2016 SE Hatch 5 sp., Tectonic
Points 644, Level 12
Level Up 88% Completed
FF Reputation: 28 Grumpy Great Standing Member
Slide the belt drive sprocket off the crankshaft.......then how about a photo. No key/keyway, correct? In my looking at some UK websites there was reference to some Zetecs including some 1.6s that did not have a keyed sprocket or pulley, and crankshaft......this is like our Duratec engines over here. The pulley and sprocket stack clampup force (probably partly explains the high bolt breakaway/loosening torque) is what maintains the correct "timing" position of the belt sprocket. Hoping that yours was keyed......this is a complication on reassembly/timing the cams, later. The pin problem.......can you rotate it at least one rotation? If you can (see if rotating/moving the crankshaft helps......this could also give you an idea on how badly bent it is), you could try lubing the pin/block threads liberally with oil and see if you can slowly work the pin out. Otherwise, it's oil pan removal.
Grumpy is offline
