Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - removal of crankshaft pulley bolt?
Old 05-07-2010, 05:15 PM   #106
Grumpy
Fan#: 43791
What I Drive: 2016 SE Hatch 5 sp., Tectonic
Points 644, Level 12
Level Up 88% Completed
FF Reputation: 28 Grumpy Great Standing Member
Yup, it wasn't coming off, puller or not. Jeez, they don't make things easy with all the variants.......but the area that you indicate as "crankshaft spindle" is a portion of the actual end face of the crankshaft with the thread/thread lead in visible? So the black/dark area is the portion of the bolt head/integral washer still to be ground off......correct? It's confusing to me because you have that outer red ring, and labelled it as "Integral bolt/washer", or did you simply mean that that is the area that was "covered" by the original bolt head/integral washer. If that is the exposed area of the face of the crankshaft how much below the front face of the pulley is it? Anyway......obviously, you have to carefully remove (try not to grind into the crankshaft) the remaining area of the head/washer that I think I can see remaining there. Actually you've done a helluva job just to get that much of the damn bolt ground off. If that is the end of the crank and exposed threads and going by the look of it.......I think you'll be able to extract the bolt shank just fine.
Grumpy is offline
