Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - removal of crankshaft pulley bolt?
Old 05-07-2010, 12:15 PM   #103
Grumpy
Fan#: 43791
What I Drive: 2016 SE Hatch 5 sp., Tectonic
Points 641, Level 12
Points: 641, Level: 12 Points: 641, Level: 12 Points: 641, Level: 12
Level Up 82% Completed
FF Reputation: 28 Grumpy Great Standing Member
I guess it's a "Belleville style" washer, designed to help prevent the bolt from backing off.......the head of the bolt must be gone then. You must be able to now see the actual bolt shank diameter. It's gotta be corrosion holding the washer on. Just give it a wack, or podger it off. I'm heading out for a few hours on a family junket.........but soak the area with a good penetrating fluid for a while if the pulley doesn't come off.......you may have to use a centre bolt/rod adaptor for that puller that you mentioned, if you need it. You should have enough of a stub of the bolt to grab and work that bolt (use lots of penetrating fluid and take your time) back and forth to loosen and remove it. Let's see what happens. EDIT.......I couldn't find the website with the photo......just in case......you could also be describing an integral washer style bolt head, where after grinding the bolt head hex off and with the fact that you apparently can't see an actual outer dia. edge/lip of a "separate" washer.......I'm wondering. The separate washer will be about 2" in outside diameter and about a 1/16" thick.
Grumpy is offline
