Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - removal of crankshaft pulley bolt?
Old 05-05-2010, 09:06 AM   #76
Fan#: 74469
What I Drive: focus lx blue
FF Reputation: 1 the_doc735 Good Standing Member
Originally Posted by a_2000_se View Post
Ok - how about locking up the piston in the cylinder, head still installed?:
- I read, someone here uses thin rope inserted into the spark plug hole
OR -
- Again on the compression stroke, fill the cylinder with motor oil. I haven't figured out what the conversion is for 'PSI to ft-lbs' in a 1.6 liter engine. Don't exceed the rated compression of your cylinder. You might get a little smoke when you start it up - again, depending on how long you let the oil drain past the rings?
It doesn't appear you are in a hurry?
This is fun......
the rope and the oil are worthy of consideration, thanks for that one! Let's just say I can't afford to rush or hurry this process; I'm not "throwing caution to the wind" ~ LOL.
This is fun? ~ this made me laugh, thanks for injecting a little humour into this scenario LOL.
the_doc735 is offline
