Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - removal of crankshaft pulley bolt?
Old 05-04-2010, 06:46 PM   #70
Fan#: 74469
What I Drive: focus lx blue
FF Reputation: 1 the_doc735 Good Standing Member
Originally Posted by Grumpy View Post
The flat area above your red arrow........just above the step. I believe that the pin should be only put under a compression load, not a shear load. You should be able to "feel" for that area by threading the pin out/in while rotating the crank back and forth when the piston is about at BDC. When you can locate/feel that step you want to have the pin fully seated/torqued so that the end of the pin hits that flat area just "above" the step. If you can feel the pin bending (not a nice solid feel) at any time when attempting to break the bolt free........stop.
"a compression load, not a shear load"?
"you want to have the pin fully seated/torqued" ~ I can tighten this up but as I said before "the pin only fully inserts at TDC" i.e. when fully tightened at this position (the step) there WILL BE still about 3mm of thread showing outside the block! ~ OK?
the_doc735 is offline
