Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - removal of crankshaft pulley bolt?
Old 05-04-2010, 04:09 PM   #68
Grumpy
Fan#: 43791
What I Drive: 2016 SE Hatch 5 sp., Tectonic
Points 644, Level 12
Level Up 88% Completed
FF Reputation: 28 Grumpy Great Standing Member
The flat area above your red arrow........just above the step. I believe that the pin should be only put under a compression load, not a shear load. You should be able to "feel" for that area by threading the pin out/in while rotating the crank back and forth when the piston is about at BDC. When you can locate/feel that step you want to have the pin fully seated/torqued so that the end of the pin hits that flat area just "above" the step. If you can feel the pin bending (not a nice solid feel) at any time when attempting to break the bolt free........stop.
Grumpy is offline
