Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - removal of crankshaft pulley bolt?
Old 05-02-2010, 03:49 PM   #50
Grumpy
Fan#: 43791
What I Drive: 2016 SE Hatch 5 sp., Tectonic
Points 644, Level 12
Level Up 88% Completed
FF Reputation: 28 Grumpy Great Standing Member
I found the photo of your referenced tool kit and it appears that the "locking" pin is shorter than the "locating" pin which makes sense because I believe that the locking pin has to be contacting the crank web/counterweight in a different location because you'll be trying to rotate the crank in a counterclockwise direction when loosening the pulley bolt, as opposed to a clockwise direction when locating the crankshaft for timing the cams. My concern was because of these photos in post #4 here: http://passionford.com/forum/technic...cking-kit.html
Grumpy is offline
