Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - removal of crankshaft pulley bolt?
Old 04-28-2010, 08:07 AM   #9
the_doc735
Fan#: 74469
What I Drive: focus lx blue
FF Reputation: 1 the_doc735 Good Standing Member
Originally Posted by sailor View Post
Posted via FF MobileJust covering all bases w/reverse thread question... (would turn out) Why NOT use impact? Normal tool when you can get at it with one... Reversing directions with an impact helps remove stuck bolts - Same as with wrench but more so as impact gets a better "hit" when you catch it`s mechanism just right - back & forth gets you that extra impact ...
Originally Posted by zetecDon View Post
To loosen the crankshaft pulley bolt you have to turn it counter clockwise. I just recently did this when I changed my timing belt. I used an impact on mine and it took it right off of there without any issues.
...So, I won't "shear the head off the bolt" then? AND back to the original question: HOW MUCH TORQUE DO I NEED FOR THIS OPERATION? Is a 450Nm wrench sufficient for the job in hand?
cheers! ~ many thanx!
the_doc735 is offline
