Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Attention 2008-2010 Focus owners
Old 04-28-2010, 08:06 AM   #1
tetra
pwned
tetra's Avatar
Fan#: 60621
What I Drive: 2009 Black Clearcoat SES Sedan
Points 13,912, Level 76
Points: 13,912, Level: 76 Points: 13,912, Level: 76 Points: 13,912, Level: 76
Level Up 66% Completed
FF Reputation: 10 tetra Great Standing Member
Exclamation Attention 2008-2010 Focus owners
I have a problem and look what I found:
TSB
10-8-5 CLICK/POP NOISE FROM FRONT END WHILE TURNING OR GOING OVER BUMPS
Publication Date: April 27, 2010
FORD: 2008-2010 Focus
This article supersedes TSB 09-18-2 to update the Service Procedure, Service Labor Time Standards and Part List.
ISSUE:
Some 2008-2010 Focus vehicles may exhibit a click/pop type noise from the front end while turning and/or driving over bumps, or a creak/squeak noise from front when driving over bumps. The noise may be isolated to front stabilizer bar end links, front upper strut bearing area, and/or lower control arm.
ACTION:
Follow the service procedure to correct the condition.
SERVICE PROCEDURE
Install Chassis Ear JSP97202 in the Rotunda Technician Tool Program or equivalent to identify and isolate the source of the noise.
Drive the vehicle over moderate bumps and perform left and right turns.
If a click/pop noise is coming from front stabilizer bar end link(s), proceed to Step 3.
If a click/pop noise is from upper strut bearing area, go to Step 4.
If a creak/squeak type noise is coming from a lower control arm, go to Step 5.
Front stabilizer bar end link click/pop noise.
Is vehicle built on or before 1/11/2010?
Yes - remove and install four (4) revised stabilizer bar end link nuts per Workshop Manual (WSM), Section 204-01; torque to 46 lb-ft (63 N-m).
No - replace affected stabilizer bar end link(s) per WSM, Section 204-01; torque nuts to 46 lb-ft (63 N-m).
Upper strut bearing click/pop noise.
Is vehicle built on or between 10/01/2007 and 10/31/2007?
Yes - replace upper strut bearing per WSM, Section 204-01; torque nuts to 30 lb-ft (40 N-m).
No - proceed to Step 3b.
Is vehicle built on or before 11/30/2008?
Yes - inspect the three (3) upper strut mount nuts for signs of looseness. Torque nuts to 30 lb-ft (40 N-m).
No - replace suspect strut per WSM, Section 204-01; torque upper nuts to 30 lb-ft (40 N-m).
Lower control arm creak/squeak noise.
Replace the affected lower control arm per WSM, Section 204-01.
PART NUMBER PART NAME
9S4Z-3078-A Lower Control Arm - Right Hand
9S4Z-3079-A Lower Control Arm - Left Hand
9S4Z-18124-C Front Strut - Right Hand, w/ Rear Stabilizer Bar
9S4Z-18124-E Front Strut - Right Hand, w/o Rear Stabilizer Bar
9S4Z-18124-D Front Strut - Left Hand, w/ Rear Stabilizer Bar
9S4Z-18124-F Front Strut - Left Hand, w/o Rear Stabilizer Bar
8S4Z-18198-A Strut Bearing
AS4Z-5K484-AA Front Stabilizer Bar End Link
W-713760-S440 Nut - Stabilizer Bar Link
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
100805A 2008-2010 Focus: Includes Diagnosing With Chassis Ears And Road Test, Labor Operation Should Be Claimed With B, C, D, E, F Or G (Do Not Use With Any Labor Operations Outside Of This Article) 0.8 Hr.
100805B 2008-2010 Focus: Replace Four (4) Stabilizer Bar End Link Nuts Or Stabilizer Bar End Links, Labor Operation Can Be Claimed With A, C, D, E, F And G (Do Not Use With Any Labor Operations Outside Of This Article) 0.2 Hr.
100805C 2008-2010 Focus: Replace One (1) Upper Strut Bearing Or Strut Assembly, Labor Operation Can Be Claimed With A, B, E, F, And G (Do Not Use With Any Labor Operations Outside Of This Article) 0.5 Hr.
100805D 2008-2010 Focus: Replace Both (2) Sides Upper Strut Bearings Or Strut Assemblies, Labor Operation Can Be Claimed With A, B, F And G (Do Not Use With Any Labor Operations Outside Of This Article) 0.8 Hr.
100805E 2008-2010 Focus: Tighten Both (2) Sides Upper Strut Bearing Retainers, Labor Operation Can Be Claimed With A, B, F And G (Do Not Use With Any Labor Operations Outside Of This Article) 0.1 Hr.
100805F 2008-2010 Focus: Replace One (1) Lower Control Arm, Labor Operation Can Be Claimed With A, B, C, D And E (Do Not Use With Any Labor Operations Outside Of This Article) 0.3 Hr.
100805G 2008-2010 Focus: Replace Both (2) Sides Lower Control Arms, Labor Operation Can Be Claimed With A, B, C, D, E And F (Do Not Use With Any Labor Operations Outside Of This Article) 0.4 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
3B438 24
tetra is offline
