Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SCT Datalogging issues PLEASE POST
Old 04-22-2010, 06:51 AM   #85
Blivit
Blivit's Avatar
Fan#: 51292
What I Drive: 2013 ST
Points 2,596, Level 30
Points: 2,596, Level: 30 Points: 2,596, Level: 30 Points: 2,596, Level: 30
Level Up 98% Completed
FF Reputation: 118 Blivit Excellent Standing Member Blivit Excellent Standing Member
Originally Posted by 1turbofocus View Post
There has to be a sensor somewhere ? Otherwise it would have to be a full manual return fuel system and the ECU have no controle over the pump correct ?
The 2010 Fuel pump ,what I understand is still controled by the ECU no?
Tom
There is no FRP sensor on the rail in a mechanical returnless system. Also, if you look at an 08+ code, there is no fuel pump voltage table. Pressure is controlled by a regulator in the fuel tank. I noticed IDS has "fuel tank pressure" which I am assuming to be what the ecu uses...but I have not logged it. I am also not sure if this is in livelink or not.
Blivit is offline
