Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 03 SVT sway bar hitting body...need suggestions
Old 04-16-2010, 06:17 PM   #10
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 29,333, Level 99
Points: 29,333, Level: 99 Points: 29,333, Level: 99 Points: 29,333, Level: 99
Level Up 60% Completed
Forum Activity 100%
More info helps! - I wouldn't bother with links since you KNOW the stock ones are the right length - I was just covering all bases just in case there's a similar aftermarket that's a little longer yet bolts up right... Many similar ones out there...
Everything normal it SHOULD try to center itself instead of walking...
But if bent it would probably try to walk until the bend is centered between the mounts...
sailor is offline
