Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 06 with SVT Interior
Old 04-12-2010, 03:26 AM   #32
Red01Focus
Fan#: 40437
What I Drive: 2001 Infa Red SE
Points 11,414, Level 70
Points: 11,414, Level: 70 Points: 11,414, Level: 70 Points: 11,414, Level: 70
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
FF Reputation: 10 Red01Focus Great Standing Member
Buy-Sell-Trade Rating: (56)
Originally Posted by insaneaudio View Post
This is all thanks to mjmallon
http://picasaweb.google.com/lh/photo...eat=directlink
For the Driver seat:
svt pin 1: driver side-airbag signal: wire to driver seat harness pin 9
svt pin 2: driver side-airbag return: wire to driver seat harness pin 10
svt pin 3: not used
svt pin 4: not used
svt pin 5: seat heaters switched power pass-through: jumper with svt pin 11
svt pin 6: heated seats switched power: wire to driver seat harness pin 5
svt pin 7: seatbelt buckle sensor signal: wire to driver seat harness pin 3
svt pin 8: seatbelt buckle sensor return: wire to driver seat harness pin 4
svt pin 9: powered seat-height power: wire to constant power
svt pin 10: powered seat-height ground: wire to ground
svt pin 11: seat heaters switched power pass-through: jumper with svt pin 5
svt pin 12: seat heaters ground: wire to passenger seat harness pin 8
svt pin 13: seat track position sensor signal: wire to driver seat harness pin 1
svt pin 14: seat track position sensor return: wire to driver seat harness pin 2
For the Passenger seat:
svt pin 1: passenger side-airbag signal: wire to passenger seat harness pin 9
svt pin 2: passenger side-airbag return: wire to passenger seat harness pin 10
svt pin 3: seatbelt pretensioner switched power: wire to passenger
seat harness pin 5
svt pin 4: seatbelt pretensioner signal return: wire to passenger seat
harness pin 6
svt pin 5: heated seats switched power: wire to passenger seat harness pin 1
svt pin 6: seat heaters switched power pass-through: jumper with svt pin 11
svt pin 7: seatbelt buckle sensor signal: wire to passenger seat harness pin 3
svt pin 8: seatbelt buckle sensor return: wire to passenger seat harness pin 4
svt pin 9: not used
svt pin 10: not used
svt pin 11: seat heaters switched power pass-through: jumper with svt pin 6
svt pin 12: heated seats ground: wire to passenger seat harness pin 8
svt pin 13: not used
svt pin 14: not used
ok so im not understanding how you get all of the functions to work on the svt seats if you have the stock square harness since the svt harness is rectangular
SEDAN REVOLUTION #13
Red01Focus is offline
