Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - ZETEC Timing Belt Replacement
Old 04-10-2010, 10:49 PM   #35
Fan#: 74316
What I Drive: 2000, Midnight Blue 2.0 Zetec ZX3
FF Reputation: 1 max505 Good Standing Member
2000 dohc zx3
I did my timing belt with the help of one of my friends using this great thread and pics. We consulted in a tank mechanic friend from the US Marines when it came to the cam ford locking tool? step' We simply used a flat file that cost nothing, and allignied the cams <which is done by turning the cams 180 to 360 and sliding the file under the space at end of two cams... and a srewdriver inside piston 1 on the passanger side and turned the engine till cylinder one was TDC {screw driver all the way to top, before going back down while turning crank shaft}
as far as the harmonic balancer bolt we simply added an extension to the socket wrench from Wal-mart / no impact wrench/and turned the starter over one time-- right off the bolt came. DO NOt HOLD THE WRENCH WHEN DOING THIS, you'll be lookin at broken bones.
Runs perfect 29.99 timing belt from auto zone 8.99 Miller 12pk
max505 is offline
