Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - "How To" SVTF Short Shifter Install
Old 10-08-2004, 05:24 PM   #8
WD40
The Librarian
WD40's Avatar
Fan#: 5157
What I Drive: '04 Sonic Blue - SVT 3Door
Points 229,755, Level 100
Points: 229,755, Level: 100 Points: 229,755, Level: 100 Points: 229,755, Level: 100
FF Reputation: 139 WD40 Excellent Standing Member WD40 Excellent Standing Member
Buy-Sell-Trade Rating: (3)
5) Remove the 4 Torx bolts holding the shifter:
Use a T-30 bit and a 3/8 drive ratchet. Firmly press down as you break the bolts loose, then turn them out.
They will be hard at first, as LocTite was used to secure them.
I broke them all loose first, then turned them out in a criss-cross pattern, as you would with wheel lug nuts.
Once all the bolts are removed, carefully extract the shifter taking care not to catch the cables.
WD40 Reverend GripShift - FF Moderator
WD40 is offline
