Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - "How To" - Cutting the Stock shifter
Old 10-07-2004, 04:27 PM   #47
jveneziano
Fan#: 13586
What I Drive: 2000 Pitch Black Sony Limited Edition
FF Reputation: 1 jveneziano Good Standing Member
I did this it was very easy. I cut mine 2 inchs. For the reverse lock out I unscrewd the fac. knob
and the boot and lock out came right off. I cut the wire tie to get the lock out, out of the boot.
After I cut the shaft I cut the lock out just below the notch where the boot was tide. I then replaced the boot to the modified lock out. Iput the boot and lock out back on the shaft, it rested on the bend it the shaft, I also put back in the origanl spring and knob. You can't tell at all. It works great and I don't have the lock out function. ass soon as i get some pics i'll post them. Thanks for all the good info!
aem cai, hyper ground kit, 65 mm throtle body, kyb dampers, vogtland springs eibach front and rear sway bars, and poly ureathane bushing. Ordering real soon mrbn exhaust.
jveneziano is offline
