Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Dome, map light wiring diagram?
Old 03-29-2010, 10:53 PM   #5
VonKaiser
VonKaiser's Avatar
Fan#: 26749
What I Drive: 2014 Dodge Charger
Points 3,119, Level 34
Points: 3,119, Level: 34 Points: 3,119, Level: 34 Points: 3,119, Level: 34
Level Up 46% Completed
FF Reputation: 1 VonKaiser Good Standing Member
Originally Posted by norcalfocus01 View Post
An add a fuse isnt an inline fuse. Its a fuse that plugs into the fuse box and uses the power off it.
Ah, ok. :)
Do you really want it to come on everytime you turn on your dome light? Think about it your driving along turn on the dome light and your LEDs come on.
Yes. These are small 3mm and 5mm LEDs. :)
The only way to run wire off the dome itself is to put wire on the clips that hold the bulb.
Wouldn't splicing the wire work?
2014 Dodge Charger
2015 Jeep Renegade
VonKaiser is offline
