Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Dome, map light wiring diagram?
Old 03-29-2010, 09:11 PM   #3
VonKaiser
VonKaiser's Avatar
Fan#: 26749
What I Drive: 2014 Dodge Charger
Points 3,119, Level 34
Points: 3,119, Level: 34 Points: 3,119, Level: 34 Points: 3,119, Level: 34
Level Up 46% Completed
FF Reputation: 1 VonKaiser Good Standing Member
Originally Posted by norcalfocus01 View Post
Moved to Interior Mods & Chat.
What I would do is get an add a fuse. You can pick them up at your local auto parts store and then you dont have to tap into any wiring and you'll be under the dash already. Just add it to one of the fuses that is hot when the car is running then have a switch in your dash.
I choose lighting chat but found it odd that it was for the exterior subforum. :lol:
Anyway, I don't want a switch I'd like the lights to come on when the dome light (opening the doors, using the keyfob etc) or map lights come on. Adding an in-line fuse is a good idea but wouldn't it be better to just add a beefier one in the fusebox since I'm running off the existing dome light (map light) line?
2014 Dodge Charger
2015 Jeep Renegade
VonKaiser is offline
