Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - That power door lock actuator looks to be a PAIN to replace.
Old 03-23-2010, 12:18 AM   #5
Benporat
Fan#: 59927
What I Drive: Focus 2012 Silver
FF Reputation: 1 Benporat Good Standing Member
Originally Posted by lbrowne View Post
Ok so I have another identical door with a known working actuator. (it's a passenger door as well)
So you're saying I have to take out the torx screws that are holding the handle assembly in place and take the whole apparatus out?
I'll give it another look tomorrow. That doesn't sound too bad now.
yes the latch assembly has the small electric motor inside which can be replaced
removing the latch assembly from the door and especially reassembly can be tricky the inside door panel must be removed
the inside and outside door handles are attached as is the locking button by long metal rods. Take a good mental picture of what goes where when you extract it
one must have a certain amount of mechanical proficiency
the easiest part is opening the assembly and replacing the motor
Benporat is offline
