Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Central locking problems - Finally a solution!
Old 03-22-2010, 02:20 PM   #29
exsodius
Fan#: 14827
What I Drive: 2014 Candy red Titanium
Points 13,017, Level 74
Points: 13,017, Level: 74 Points: 13,017, Level: 74 Points: 13,017, Level: 74
Level Up 42% Completed
Level up: 42% Level up: 42% Level up: 42%
Forum Activity 5%
FF Reputation: 1 exsodius Good Standing Member
In english:
This problem will come back unless you keep spraying som wd-40 on the microswitch. I have made it simple to do. Just have the lowest screw on the door unscrewed all the the time. You know the 3 torx screws at the door lock. Now i can spray wd-40 in that hole whenever i want. It works very good, i can even hear a click from the central lock while spraying. And then it suddenly works again. It would have been nice if i could find a spray that is better than the wd-40 so i wouldn't need to spray it once a month.
In norwegian:
Problemet kommer tilbake så lenge du ikke smører mikrobryteren. Jeg har gjort det så enkelt nå at jeg har den nederste skruen av de 3 skruene på låsen i døren utskrudd hele tiden. Så nå er det bare ett hull der som jeg kan spraye inn wd-40 når jeg vil. Det fungerer så bra at jeg til og med hører mens jeg sprayer ett klikk fra sentrallåsen nå den plutselig virker igjen. Det er bare litt wd-40 som skal til. Hvis jeg hadde funnet en spray som var bedre hadde jeg sikkert ikke trengt og gjort det 1 gang i mnd.
Ford Focus wagon 2014 1.0 Ecoboost 125 hk Candy red
exsodius is offline
