Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - That power door lock actuator looks to be a PAIN to replace.
Old 03-22-2010, 02:29 AM   #3
Benporat
Fan#: 59927
What I Drive: Focus 2012 Silver
FF Reputation: 1 Benporat Good Standing Member
Originally Posted by ah1f39 View Post
The actuator is built into the latch asemblely. You will have to replace the latch. There is no way to repair the power actuator.
the above is mostly true
the actuator is specific to left or right door and front and back
it is also somtimes specific to a certain run of production- the design or supplier may change in the middle of production
I bought an actuator on ebay for a very small sum of money
that I thought was the correct part- turns out that it was ever so slightly different and would not fit
I opened both actuators and found that there is a small electric motor inside
with a wormgear shaft - both are identical
just swapped them out and replaced the original actuator with the swapped motor and works perfectly
looked like this:
http://cgi.ebay.com/ebaymotors/Ford-...Q5fAccessories
by the way the dealer wanted almost 600 USD for a new latch/actuator
assembly - purchased a used one on ebay for 25 USD!!!
Benporat is offline
