Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How-To: 2008 - 2011 Halo Projectors Light Installation
Old 02-12-2010, 07:56 AM   #65
Motor City Madman
Motor City Madman's Avatar
Fan#: 67832
What I Drive: 2009 silver SE Coupe
Points 190, Level 3
Points: 190, Level: 3 Points: 190, Level: 3 Points: 190, Level: 3
Level Up 80% Completed
FF Reputation: 1 Motor City Madman Good Standing Member
Originally Posted by arasky View Post
h9 hid bulb-> h13 harness-> headlamp.
After having been able to see the lights myself, why couldn't you use the h9 harness on the actual light, under the big rubber cover. You would unplug the bulb from it's connector and put the h9 harness between that connector and the HID bulb. By using the h13 harness on the h13 plug on the headlight, you're, essentially, disabling the high beam shutter because h13 HID harness has no means to activate the high beam on the new headlight. Just a thought.
Motor City Madman is offline
