Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SVT P0125 code
Thread: SVT P0125 code
Old 02-10-2010, 01:55 AM   #4
dirtbrown
what it be like
dirtbrown's Avatar
Fan#: 40563
What I Drive: 03 EAP
Points 43,229, Level 100
Points: 43,229, Level: 100 Points: 43,229, Level: 100 Points: 43,229, Level: 100
FF Reputation: 27 dirtbrown Great Standing Member
Buy-Sell-Trade Rating: (3)
Originally Posted by BC_ZX3 View Post
Low coolant level, faulty coolant temperature sensor or stuck open thermostat are the likely causes.
The code is telling you that the ECU can't operate the fuel system in a closed loop fashion - where the air fuel ratio is "tweaked" for optimum efficiency using inputs from various engine sensors - because the engine is taking too long or never reaching its normal operating temperature, a prerequisite to entering closed loop functionality. Consequently, it's may be running rich all the time in an attempt to "warm up".
wow this makes sense...my car just threw this same code at the same time as p0420 something about my car running too rich bank 1 or something along those lines...could a bad thermostat or temp. sensor be causing my car too through this other code
dirtbrown is offline
