Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Do you warm your car up in Winter? Poll..
Old 02-04-2010, 10:33 PM   #75
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
Originally Posted by Executionerhk View Post
so a_2000_se,
will letting the car warm up until the needle of the temp. gauage moved be better off for the car in terms of wear and tear?
or driving it under 2.5K rpm is better off?
Nope. Not on a properly maintained newer car. Just a waste of gas, time, money and contributing to the pollution problem.
As long as you got good oil pressure, good fluid levels, and a daily driver (not one that's been sitting for an extended period or one that's waiting for the green light on the 'xmas tree' at the strip on a -10 F day just after start-up) you can put it in drive and drive away.
insert disclaimer here.....
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
