Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Do you warm your car up in Winter? Poll..
Old 02-03-2010, 10:41 PM   #73
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
Originally Posted by Executionerhk View Post
this is interesting...
but cars do run a little different, a little worst when you just start it up.
how could this be explained?
i really want to know because if i buy a car. i really wanted to keep until it dies..
Cars run a little different when cold vs. warm because of machining tolerances. Heat expands, Cold Contracts. A few thousandths or ten thousandths of an inch can make a noticeable difference especially if it was in the right/wrong part/place - compression/timing.....
Machining and tolerances have gotten better and more consistent compared to decades ago, engines are tighter now. Newer cars use thinner weight oils as proof of this. Couple that with better fuel delivery, F.I. vs. carbs and you have two of the biggest reasons why.
The car was designed to run at its best when at the higher normal operating temperature, when the tolerances were the smallest - before wear widens the gaps.
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
