Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - A little here and there.
Old 02-01-2010, 10:23 PM   #15
RSVT170
FocusRush
RSVT170's Avatar
Fan#: 28451
What I Drive: '13 ST2 & '05 ZXW
Points 16,560, Level 82
Points: 16,560, Level: 82 Points: 16,560, Level: 82 Points: 16,560, Level: 82
Level Up 43% Completed
FF Reputation: 42 RSVT170 Great Standing Member
Buy-Sell-Trade Rating: (13)
Originally Posted by FocusontheZX View Post
Dude! Do a write up on the full size spare! I want to have a full size sooo bad!
It's really simple.
Buy extra wheel and tire
Remove doughnut
Force the spare in. It's really tight, but just keep pushing and it will slide in. (Gross Stop Thinking What You're Thinking!)
As for the carpet, I just placed it back in the car with the spare in place and drilled holes on either side and the top of the tire (be carefully not to drill into the tire!).
Took both the carpet and tire out and placed it on some sawhorses. I lined up the tire on the backside of the carpet with the holes I drilled earlier. then I traced with a sharpie around the tire.
I then took the tire off and used a jig saw to cut the carpet. I cut on the inside of the line about 1/4". I test fitted everything and then used a dremel to fine tune it.
Done.
It's really simple.
RSVT170 is offline
