Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Basic Bolt ons: Exhaust Headers/Flex Pipes
Old 01-09-2010, 06:57 PM   #26
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
What I Drive: 2007 TorD-Red ZX5 SES
Points 12,348, Level 72
Points: 12,348, Level: 72 Points: 12,348, Level: 72 Points: 12,348, Level: 72
Level Up 75% Completed
FF Reputation: 77 S0C0nFused Excellent Standing Member
Originally Posted by gokart2 View Post
Im in a related field.
Good! You are now our resident expert!
So what do you think? Would a wrapped header/flex pipe retain enough heat to warm a retail aftermarket HF cat (OR a racing cat) as quickly as the OEM setup? Would a cold header/flex pipe act as a heat sink initially to rob the cat of startup heat?
Is +750*c (1382 degrees Fahrenheit) typical for a gas engine? Or could you obtain the EGT of a Duratec engine? Is that the light-off temp for a cat?
Notes:
I specified header wrap as from my reading it retains more heat (I.E. works better) than a jet coat or similar.
I did not specify wrapping the cat as I don't know if doing so is recommended. Would the cat burn out prematurely?
Steeda SRI w/CAI intake. Trubendz SS 2.5" . FR Susp/Struts. Tune by Tom (FocusPower). Rota Grids. SAP rear spoiler. Custom front air dam, rocker panel bits and Rear valance.
Last of the Hatches #28
S0C0nFused is offline
