Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - "How To" - VF Engineering Rear Mount-Install Pics
Old 09-27-2004, 02:21 PM   #5
WD40
The Librarian
WD40's Avatar
Fan#: 5157
What I Drive: '04 Sonic Blue - SVT 3Door
Points 226,961, Level 100
Points: 226,961, Level: 100 Points: 226,961, Level: 100 Points: 226,961, Level: 100
FF Reputation: 139 WD40 Excellent Standing Member WD40 Excellent Standing Member
Buy-Sell-Trade Rating: (3)
7) Install the new motor mount just as you took the old one out by rotating it into position.
8) Install the forward most bolt into the gold plate. (Hand tighten only at this point)
9) Install the forward most motor mount bolt. (Hand tighten only at this point)
10) Using a 2X2 as shown (or equivalent),
gently pry the engine/transmission assembly forward to line up the rear motor mount bolt hole.
11) Install the rear motor bolt. (Hand tighten only)
Definition of “Hand tighten only”:
Using a ratchet and socket, snug up the bolt, but don’t torque all the way tight.
WD40 Reverend GripShift - FF Moderator
WD40 is offline
