Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Speaker wire Routing: Amp to Doors ????
Old 09-26-2004, 05:42 PM   #2
focuson03
Formerly Focused
focuson03's Avatar
Fan#: 556
What I Drive: 2007 Galaxy Gray Mazda3 GT
FF Reputation: 1 focuson03 Good Standing Member
Buy-Sell-Trade Rating: (9)
if you're running a four channel, the best way to do it is to run new wires from the amp to the rears, then use the factory wiring to the rears and connect the fronts (from the amp) to it, then connect the front and rears together in the harness behind the radio. that method requires no re-routing of speaker wire to the door. if you're only using a two channel, i'd recommend running new wires to the back of the deck. . .
Mazda3s Grand Touring 5spd., RacingBeat Springs, F2 CAI, Corksport Rear Motor Mount, Hotchkis Sway Bars
-Josh
focuson03 is offline
