Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Speaker wire Routing: Amp to Doors ????
Old 09-26-2004, 05:22 PM   #1
FocusInCali
FocusInCali's Avatar
Fan#: 7987
What I Drive: 01 SE Wagon
FF Reputation: 1 FocusInCali Good Standing Member
Buy-Sell-Trade Rating: (5)
Who's doing what?
1) Are you running new speaker wire from the amp all the way to the door, which requires drilling new holes in the body and door?
2) Are you doing the same as above, but running the wire out the side of the door opening (near dash) to the side of the door panel, which exposes the wire only when the door is open?
3) Or, are you running the new wire to splice into the old wire behind the HU?
The obvious was to run the wire through the rubber boot going to the door. But I found it is a plug, not a boot; so that won't work. Unless I tap into the speaker wire near the kick panel before it goes to the plug, but I'm thinking drilling holes and using grommets would be better.
Those of you with amps, how did you route your speaker wires?
DRZ9255 ~ Arc Audio 4150XXK ~ Oz Audio 180CS ~ IDQ12 ~ iPod ~ Sirius
FocusInCali is offline
