Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Researching: Spray Bomb Painting : Proper Techniques.
Old 12-11-2009, 11:00 AM   #17
norcalfocus01
Guest
Fan#: 55603
What I Drive: White N Gold 2001 Sedan
FF Reputation: 132 norcalfocus01 Excellent Standing Member norcalfocus01 Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Originally Posted by 02Zetechse View Post
I have to disagree with Norcal on using grey primer to go from black to red .Although your results will prolly be unnoticeably different I would use the Red Oxide Primer. Its a red/brown primer . Either way its done will work perfectly fine. The red paint may cover better on the Red Oxide Primer.
The reason you want to use a differant color primer, is so when paint the finish coat on, if you cant see the primer, you know youve put enough paint on.
Hi end auto painters used to use red oxide primer, under yellow, blue, black. Just so they knew they had put an even full coat on the car.
norcalfocus01 is offline
