Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Ask your spark plug, wires and coil questions here
Old 12-06-2009, 03:56 PM   #351
blackjack
Fan#: 69988
What I Drive: Black 03 SVT
FF Reputation: 2 blackjack Good Standing Member
Buy-Sell-Trade Rating: (22)
Originally Posted by WD40 View Post
Do you have an aftermarket tune?
You might want to get a hold of your tuner if so.
Looks like #3 is running really lean.
This is a very common problem on these cars, and you should have it looked at before something goes...BOOM...
If you search around these forums, you'll see that about 50% of the engine failures are due to the #3 piston losing it's upper ring land because it was running too lean.
Not trying to scare you, but if it were me I'd want to get that looked at.
FWIW, here's my observations on that same plug:
Spark Plugs Replaced
I made sure all the intake to head hose clamps were tight, ran a can of injector cleaner through it, and had the tune adjusted slightly.
Haven't seen a lean problem in that cylinder since then.
WOW, will be checking mine tonight.
Is there any gains with a COP set up on the SVT?
blackjack is offline
