Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - UEGO bung location for aem afr gauge
Old 12-02-2009, 08:52 PM   #16
focusZX505
FOCUS REVOLUTION
focusZX505's Avatar
Fan#: 19251
What I Drive: 08 Black Coupe 14 fiesta ST
Points 7,060, Level 55
Points: 7,060, Level: 55 Points: 7,060, Level: 55 Points: 7,060, Level: 55
Level Up 55% Completed
Level up: 55% Level up: 55% Level up: 55%
FF Reputation: 4 focusZX505 Good Standing Member
Originally Posted by seige123 View Post
I'll do the 2nd o2 from what tom said for now. I live in illinois and its illegal to remove the cat but I have gone to do my emmision testing and they do not check under the hood or sniff the tail pipe. They just do the obdII. So I think I would be fine as long as I do not get a failed signal on the o2 sensor readings, which from what Tom said, it should not be a problem if the rear o2 sensor is disabled (this I have to test out unless someone has done it already in illinois).
Also, Im just setting up for a turbo in the future and a header would be a waste of money for me unles I get another focus or I could sell it locally...
You are right on IL my buddy has a 2.3 swaped turbo focus which has a cut off after the down pipe and he passed emmsions in IL
I am emissions certified and In IL what they told me about people like us" that cheat the test" is that is to small of a percentage to worry about
So if ur in IL and the tune disables the rear O2 you'll be fine
FOCUS REVOLUTION
FSWERKS
MASSIVE SPEED SYSTEMS
2.5 swap underway
focusZX505 is offline
