Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Clunking rear shock mounts: Solved?
Old 10-28-2009, 03:40 PM   #9
malim
malim's Avatar
Fan#: 55004
What I Drive: 2007 Ford Focus ST - Black
Points 1,139, Level 18
Points: 1,139, Level: 18 Points: 1,139, Level: 18 Points: 1,139, Level: 18
Level Up 39% Completed
FF Reputation: 4 malim Good Standing Member
Originally Posted by Geezer View Post
Any shock that has a shaft that uses a single nut and bushings above and below the upper shock mount should never be fully tightened. That fully compresses the two rubber bushings which can cause noise and doesn't let them do their job correctly. The top shock mounting shaft has to be able to move and not be bound up. Most install directions that come with shocks clearly indicate how much the top bushings are to be compressed. Most of the time there's even a graphic. In most cases you're suppose to "slightly" compress the bushings and then stop tightening.
That sentensed confused me that's why i asked.Geezer is saying that it has to move.
malim is offline
