Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Quick question
Thread: Quick question
Old 10-14-2009, 03:47 PM   #2
WD40
The Librarian
WD40's Avatar
Fan#: 5157
What I Drive: '04 Sonic Blue - SVT 3Door
Points 229,755, Level 100
Points: 229,755, Level: 100 Points: 229,755, Level: 100 Points: 229,755, Level: 100
FF Reputation: 139 WD40 Excellent Standing Member WD40 Excellent Standing Member
Buy-Sell-Trade Rating: (3)
That's an easy one...ST.
That is, unless you also have SVT rear brakes, which IIRC puts you in FSP.
(You mentioned SVT kit, which I assume is dampers/springs, but I guess it could be brakes too.)
Here's a hint on classing cars.
If it doesn't specifically state that you can do it in the rules, then you can't.
EX:
Stock says nothing about springs, so you can't change springs in Stock class.
ST says you can change springs, so you can put on different springs in ST class.
But then again...
I see those aftermarket upper and lower grilles.
If there's a real diehard in your club, you could get bumped clear to EP.
(That's the first time grilles are mentioned)
17. PREPARED CATEGORY
17.2 BODYWORK AND STRUCTURE
A.Grilles may be removed,modified, or substituted.
WD40 Reverend GripShift - FF Moderator
WD40 is offline
