Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - funky thumping from front end
Old 10-30-2003, 07:25 PM   #6
bfocused's Avatar
Fan#: 63
What I Drive: I now drive a 2009 Focus SES
FF Reputation: 2 bfocused Good Standing Member
As promised, I have the TSB to post. This TSB is #03-20-2. It addresses (and I am quoting here) Suspension-- "Creaking,crunching,grinding,or rattle noise from front suspension at slow speeds over bumps and/or while turningIssue- Some 2000-2003 Focus vehicles may exhibit a front end creaking, crunching,grinding and/or rattling noise from the front suspension at slow speeds and or/while turning.
Service procedure is to inspect front strut fasteners, and confirm they are tightened to correct torque. Well it goes on and on, I won't bore you to death with it, go to your local Ford Service Dept and ask for them to check this out if you have this noise.
My car is doing it big time. And I have an appointment to have this done.
This TSB supersedes TSB # 03-15-3. And remember this is a Technical Service Bulletin, not a recall. Normal warranty coverages apply--- 3 yrs 36k, unless you have an Extended Warranty.
Hope this helps
"The present day composer refuses to die"
Edgar Varese 1883-1967
bfocused is offline
