Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - ABS sensor test with meter?
Old 10-10-2009, 09:16 PM   #10
jarchie
jarchie's Avatar
Fan#: 51811
What I Drive: 2010 Midnight Black SES 4-Door,
Points 771, Level 14
Points: 771, Level: 14 Points: 771, Level: 14 Points: 771, Level: 14
Level Up 72% Completed
FF Reputation: 5 jarchie Good Standing Member
At Ford, we refer to them as Active and Passive. Passive sensors are tested with an OHM meter and can be tested to see if they produce AC voltave (in milivolts) and Active require a 12V power source and are tested in AMPS. Your meter has to be wired in series with the negitive lead from the sensor to the module and the positive wire has to be complete with the key on. The signal should toggle from 7mA to 14mA. If you are in Charlotte NC week after next, I am teaching Advanced Brakes.
If you can make it go, I can make it go faster.
SEDAN REVOLUTION MEMBER #72 TEAM DURATEC #30
FORD F.A.C.T. INSTRUCTOR, FORD TRAINING CENTER INSTRUCTOR, TECHNICIAN. LOVER & OWNER
jarchie is offline
