Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - ABS sensor test with meter?
Old 10-09-2009, 09:18 PM   #7
boatingfool
Fan#: 69193
What I Drive: 2002 Red Focus SVT
Points 1,643, Level 23
Points: 1,643, Level: 23 Points: 1,643, Level: 23 Points: 1,643, Level: 23
Level Up 44% Completed
Forum Activity 6%
FF Reputation: 1 boatingfool Good Standing Member
The car does not have traction control.
The front wheel sensors read 3.625mohms/3.680mohms. I don't remember what the rears were and I just cleaned up for the night (frustrated) .
I will check the rears tomorrow.
Again, I am only able to ohm the sensor if I have the test leads oriented one direction. If you reverse the leads, it reads open.
Thanks for the help.
Vincent
Oh, the front bearings were CFM but Ford OEM. The 2nd set of front I have to install were purchased from Trousley and are the same exact ones. I checked the black ring and it has a slight magnetic field. I removed the driver's side sensor and placed a ferrous tool (Snap on pick) and the wheel sensor ring pulls at the pick.
boatingfool is offline
