Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Spi head gasket
Thread: Spi head gasket
Old 10-05-2009, 10:02 PM   #6
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
Buy new bolts, if you think you're going to be keeping that car and engine until the doors fall off, do some research and see if ARP makes bolts for the engine. Those shouldn't stretch.
Are the 'ARP' bolts torqued to the same spec's as the OEM bolts?
The SOHC are one time use, $24 - Felpro. The DOHC are rated for two uses before replacement - aren't they?
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
