Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - "safe" afr for high compression NA...
Old 09-30-2009, 04:57 PM   #10
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
What I Drive: 2010 BMW 135i
Points 23,393, Level 94
Points: 23,393, Level: 94 Points: 23,393, Level: 94 Points: 23,393, Level: 94
Level Up 5% Completed
Level up: 5% Level up: 5% Level up: 5%
Forum Activity 14%
Activity: 14% Activity: 14% Activity: 14%
FF Reputation: 53 iminhell Excellent Standing Member
Buy-Sell-Trade Rating: (4)
If the later is true, then one would have to assume that the knock sensor is hindering you. More timing, to a point, should yield more power. That also assumes the AFR is correct.
Honestly though, you'll never know unless you put it on the rollers.
I think I'm running more compression than you and I've just got a off the shelf chip, and I'm pretty sure I'm not experiencing any knock (though I've no way to substantiate that).
Out of curiosity, did you have to gap your plugs down too?
I have to run a .040" or smaller gap or I seem to blow out spark, maybe it's knock though; .045" and I feel it for sure. BTW, I seem to be getting by fine on pump 92.
Also remember that with more pressure comes more heat. Not sure what you're running for plugs, but I'm having good luck with the NGK LZTR5A-13 / 4998 gaped @ .035".
13 years, 124,000 members and still no sponsored racing.
*your ad here*
*and here*......................................................................................................... *there's a wide open area here too*
*still space available*
iminhell is offline
